Resultados 1 al 2 de 2
Tema: "Pelican" vs."Non-Pelican" F1's car nose brief CFD analysis
    I exhibit below, a brief report related to the influence of a “bulge” on the airflow that goes through the underside of a F1's car nose.
    Before I do anything else, I want to thank my fellow at f1-gears.com, Roller, who very kindly, made both geometries with Catia code.
    These are both noses (non-pelican/pelican), imported to the meshing code (Gambit):
    The “non-pelican” nose:
    subir fotos online
    The “pelican” nose:
    sube imagenes
    As in the previous step-less vs. stepped F1's car nose brief CFD analysis:
    - They have been used the real length between lines A-A and B-B (925 mm) besides the minimum external dimension (vertical) at the section A-A (275 mm) and the minimum external dimension (vertical) at the section B-B (400mm).
    - It has been set, too, an airflow's speed of 50m/s because that's the maximum allowed by FIA (2013 Formula One Sporting Regulations) during wind tunnel testing [Rule 22.10].
    This is the velocity vectors chart, for the “non-pelican” nose:
    imag
    Enlarged view of the above image:
    subir fotos gratis
    This is the velocity vectors chart, for the “pelican” nose:
    imagenes gratis
    imagen
    Velocity vectors comparative chart for both noses:
    subefotos
    We can see, that the presence of the bulge under the nose increases airflow's speed.
    sube imagenes
    In addition to velocity vectors, we are able to analyse velocity and static pressure contours, too.
    If we look at the contours of velocity, we can see how airflow's speed increases for the “pelican” nose case.
    subir imagen
    subirimagenes
    Static Pressure contours comparative chart for both noses:
    sube imagenes
    imagen jpg
    For the “pelican” case, there will have a bigger static pressure gradient, in other words, the “pelican” nose (such as they[both noses] were drawn) will create “more downforce” than the “non-pelican” one.
    We should note that, because we have not taken into account the front wing elements (main profile, flaps, etc.), after the iterative process we obtain “positive” values of the coefficient “cl” (downforce coefficient).
    More than the values obtained for the downforce coefficient, what is truly important here, is its change as the “non-pelican” or the “pelican” one, may be the case.
    “Non-pelican” nose results:
    subir foto
    “Pelican” nose results:
    sube imagenes
    We can see that clpelican<clnon-pelican, in other words, the presence of such a bulge underneath of the nose, induces a “more negative (smaller)” downforce coefficient (0.23<0.30).
    I hope you liked it.
    Regards, MarleneKberg.
    Última edición por llumia; 04/08/2014 a las 13:17
    Pelican is giving some advantages and it is the new trend of this last seasons.
