Página 3 de 11 PrimerPrimer 12345 ... ÚltimoÚltimo
Resultados 61 al 90 de 311
Tema: F1 2016 - Nº 8 - EUROPA
    WILLIAMS RACING Verified account ‏@WilliamsRacing
    T4: a 90-degree right-hander heading up through the trees to T5 #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago T7: heading into the city’s Old Town, Icheri Sheher, alongside the fortress walls #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Start of the second sector has a series of relatively sharp corners in quick succession from T7-12 #WilliamsTrackWalk
    T7-T8 – the second narrowest part of the circuit at just 7.5m! This will be challenging! #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago T8 exit by the Old City gates on left with amazing architecture - very tricky uphill section! #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago T8 exit is the narrowest part of the circuit at just 7.1m!
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Widens to around 11m on exit of T11 before reaching T12 #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Slight uphill into high-speed T13 - likely to be flat #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago T15 – left-hander with temporary asphalt also laid down here #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago T16: low-speed, traction important on exit before getting on the power into high speed section #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Wide corner at 17.6m mid-corner & a little off-camber so will be tricky coming round into the sun #WilliamsTrackWalk
    0 retweets 1 like
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago One of the most notable features here is the flat out section from T16, through the start-finish line to T1 #WilliamsTrackWal
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago T18: the city’s ancient defensive structure, the Maiden Tower #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Track widens out to over 18m through T18 #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago May need to lift somewhere through this section to get on the power early in T19 #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago T19: track narrows from 18m to 10m through T19 as well so quite narrow #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Hello again to the first sector of the track through the barriers! #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Exit of T20 flat out along the 1500m long drag across the start-finish line to T1 #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Pit entry: looks challengingly tight entering from full speed! #WilliamsTrackWalk
    WILLIAMS RACING ‏@WilliamsRacing 2h2 hours ago Start-finish, paddock & garage all located in Azadlig Square #WilliamsTrackWalk
    Que no se levante:
    Albert Fabrega ES ‏@AlbertFabrega 31m31 minutes ago Este es el grueso d asfalto q han puesto sobre la zona adoquinada del #BakuGP. 20 cms en dos capas...
    Que no se levante:
    Albert Fabrega ES @AlbertFabrega 31m
    Pues ese asfalto creo que es especial para poderlo retirar despues sin dañar el adoquinado ¿no?.
    Muchísimas gracias por los paseos fotográficos por el circuito, llumia. La verdad es que visto así tiene zonillas más que interesantes.
    Travesía T19-T20: Momento preciso en el que un Lada adelanta a un McLaren Honda MP4-31, que no se ve en la foto
    Solo nos falta enterarnos si el coche que no se ve es el caballero de la OBE o el Sr. Embajador.
    claro ... ya sabíamos que a fecha de hoy, el Ferrari es mejor que el auto de los hijos de Laren , pero desde ese ángulo no se ve que es la spec.B del Ferrari destaño...
    por el más que extenso reportaje fotográfico
    Secuencias de curvas entre la 8ª y la 10ª (T8-T10):Izquierda-Derecha-Izquierda-Derecha
    No me diréis ... que no está "a huevo" para entrar a por unas Ray Ban... pero con el coche y todo.
    El lúnes que viene ... la tienda puede parecer "zona de combate"
    Por lo menos , el que se vaya a la escapatoria tiene una buena salida...
    Pirelli teme problemas en las rectas de Bakú
    Paul Hembery, Pirelli Motorsport Director | hace 7 horas
    El director de Pirelli, Paul Hembery, admite que su empresa tiene miedo por el asfalto de las largas rectas de Bakú que podrían dar lugar a fallos en las gomas.
    Los neumáticos pueden estar bajo amenaza por las potenciales deformaciones que pueden sufrir por la combinación de altas velocidades y curvas fuertes.
    Así fueron los problemas que sufrió Michelin en el Gran Premio de Estados Unidos 2005, y se convirtió de nuevo en motivo de debate después del Gran Premio de Bélgica del año pasado, cuando Sebastian Vettel sufrió un reventón.
    Eso llevó a un control más exhaustivo de las presiones y temperaturas por parte de la FIA y Pirelli.
    Baku cuenta varias rectas (en concreto una de 2,2 km), y las zona de alta velocidad entre las curvas 17-20 antes de volver a boxes supone un desafío inusual para Pirelli.
    "Las largas rectas pueden crear problemas de deformación", contó Hembery a Motorsport.com. "Parece ser un circuito en el que no debería haber grandes dramas, pero tiene esa recta en la cual deberíamos tener mucho cuidado al gestionar estos problemas.
    "Si vas a un nuevo circuito, te puedes encontrar algunas sorpresa. La tendencia de los nuevos circuitos en los últimos años es la de superficies lisas con un bajo nivel de desgaste, pero hay una recta muy agresiva y las deformaciones de los neumáticos es algo que debemos gestionar, es un aspecto de la integridad de los neumáticos que tenemos que controlar bien".
    Mientras tanto, fuentes cercanas a la F1 han expresado sus miedos ante una superficie temporal de asfalto que se ha colocado sobre el empedrado y que, unido a las altas temperaturas de 32-34ºC que se esperan el fin de semana, podrían dar lugar a que la pista se quebrara.
    "Hay que revisar todas estas cosas, porque a veces parecen algo normal hasta que pasas por ahí.
    "Si se produjera una ruptura de la superficie temporal sería un problema muy grande, porque repararlo no es fácil.
    "Es algo que necesita ser controlado y revisado. De hecho, Singapur tiene algo similar. Revisamos algunos de los puntos de pavimentación que han cambiado ligeramente el recorrido del circuito este año".
    Fuente : http://es.motorsport.com/f1/news/pir.../?r=53505&em=1
    De camino a Bakú.
    Y ya dentro del avión...
